http://rsb-parts.de/zuendkabelhalter_zu ... etail.html
here you get the clips
update thread
Re: update thread
The Mann W920/8 is slightly shorter than the 930 and will fit directly to the block without fouling on the chassis. It also has the same 2.5 bar Bypass opening pressure as the W930.Karl wrote:Ford 302: Using the Mann W930 filter , 2,5 bar bypass opening and anti drain back valve, with 90 deg. adapter and sandwich plate for oil cooler take off.
Seven years now, no leaks, no problems!
Re: update thread
Clive, don't talk about filters, you'll get us all in trouble!
