Schuco 1/12 289 model
Re: Schuco 1/12 289 model
Andy,
Thanks for the explanation on the fuel lines for IDF's. I had already realised that it was definitely a fuel manifold mounted above the coolant hose but I couldn't reason why it would go to the scuttle but a fuel pressure gauge is now the most obvious. No I can't look under the dash!
I'll try to tuck the bent pipe down to hide the kinks.
It's a shame that with so much attention to detail by adding so many under bonnet parts that they shoot themselves in the foot with a wonky moulding. Also the rear tyres not being wider than the fronts is a bit of a basic over sight.
As my other half says I'm always finding fault !!
If David reads this I can advise that the spare tyre is a very tight fit in the boot!
:D
Tapped wrote:Mine has a friend now too
Hi Paul,
Where did you get the 427 from?
That's a bloody good model, Andy.
andyg
Post by andyg »
Thanks Roger - it's actually a semi working one too!
Anyone after a suitable show case could try
Anticsonline
They do a 364 x 186 x 121 case for £20 which I might investigate.
Tapped
Post by Tapped »
Hi Paul,
Hi Paul
eBay. It's the Kyosho in the Sebring livery. You can get it in blue too (road spec in blue is NLA)
It came from Spain, seller was Escala-18
Tapped
Post by Tapped »
All the catches and door latches work in the Kyosho!
