Body style choice
Re: Body style choice
I see the body shape starts as a 39PH
Post by agnoraan »
You could well be right there Peter :wink: I'm going to take various styling cues from the cars I like and try to make a period looking race car. I don't really want to replicate any one particular car though. I like the front end of mine, with the brake ducts and "letterbox" oil cooler opening, so I might go down that ruote, but that's a good way off so I'll see how it goes when it's time.
Oh yeah, it goes out in the rain too :wink: :lol: 8)
catsx11
Post by catsx11 »
peterc wrote:I see the body shape starts as a 39PH
There aren't many 39PH features on that body to my eye; other than bonnet & hardtop it appears to be 'standard' FiA.
catsx11
Post by catsx11 »
Post by agnoraan »
Hi Alan, It's pretty watertight, the front of the screen doesn't need any duct tape on it as I've made it so that the top of the screen frame, butts up against a foam seal that's bonded to the roofs inside leading edge. The bottom of the sidescreens also have a foam seal, sealing the frame to the door top. The only place that can let in a little water sometimes is the sliding window bottom rail and that's only if it's really raining heavily. On the move it doesn't seem to collect water, so it's not an issue.
Post by agnoraan »
Ah, Nik, you need vision :wink: with a lot of squinting and maybe alcohol, It's all there before you, you just can't see it :lol:
agnoraan wrote:Hi Alan, It's pretty watertight, the front of the screen doesn't need any duct tape on it as I've made it so that the top of the screen frame, butts up against a foam seal that's bonded to the roofs inside leading edge. The bottom of the sidescreens also have a foam seal, sealing the frame to the door top. The only place that can let in a little water sometimes is the sliding window bottom rail and that's only if it's really raining heavily. On the move it doesn't seem to collect water, so it's not an issue.
No it isn't, leaks like a sieve. Would have an inch of water in the footwells if it didn't just run out of the holes. You're right about when on the move, it doesn't collect anything.
Are we still talking about the Landie?
agnoraan wrote: Ah, Nik, you need vision :wink: with a lot of squinting and maybe alcohol, It's all there before you, you just can't see it :lol:
...Or a LOT of cutting, grafting, filling, blending and whatever other alchemy you perform! :P
Post by agnoraan »
Fibreglassing Nik, that's what you left out, it's the spawn of the Devil that stuff :lol: :lol:
