They look nice Peter.
Unless I'm missing something, I can't see a problem with the pads slightly overlapping the outside edge of the disk. It will stop them getting that ugly ridge around the edge as the disk wears.
Having said that, I've done over 20,000 miles in mine and there's no sign at all of any wear on the disks, so it will be a very, very long time before any ridge develops.
I was thinking of filing the "Wilwood" off mine and repainting them black as I don't like to see the branding through the wheels.
Disk brake options
Re: Disk brake options
That was what I was thinking too. I'll probably have some VHT paint spare from redoing the block black, but it only goes to 288 degrees C, so maybe not enough? If I end up doing this I'll post you what's left in the can if you want Paul!Paul Blore wrote: I was thinking of filing the "Wilwood" off mine and repainting them black as I don't like to see the branding through the wheels.
I repainted my Princess 4 pot calipers with Halfords Brake Caliper paint when I rebuilt them in 2006. Ten years and 35,000 miles covered, they are still holding up.
Hi Andy,amulheirn wrote:That was what I was thinking too. I'll probably have some VHT paint spare from redoing the block black, but it only goes to 288 degrees C, so maybe not enough? If I end up doing this I'll post you what's left in the can if you want Paul!
I've got some UVHT (Ultra VHT I think) black paint that I use on my exhausts and headers and I'm pretty sure they get much hotter than my callipers, so I'll give that a go.
Good find Clive, I hadn't realised there was specific paint for brake calipers. Presumably it isn't affected by brake fluid either.
It never comes in contact with brake fluid.
Hi guys
Yes Paul, I could easily agree that the odd mm of pad over hanging would keep the outside corner clean and tidy.
Its just the pads don't align with the full available swept area of the disc. I assumed that by moving in 1-1.5 would not only make full use of pad but also prevent an unused ridge on the pad and an equivalent ridge on the inner part of the disc.
Maybe I 'm being too perfectionist but then again its not actually been high enough on my to do list to have been corrected in 15 years!
Why, what do you use in your bakes?clive wrote:It never comes in contact with brake fluid.
There's always the possibility of some leakage when either bleeding the brakes or replacing the fluid.
- Phil Riley
Like the Cubans maybe? Shampoo, sugar and in Clive's case, probably a single malt!!!Paul Blore wrote:Why, what do you use in your bakes?clive wrote:It never comes in contact with brake fluid.
Just Dot4. I can never recall fluid leaking onto the caliper when bleeding, but if I did a wipe with a damp cloth or wash with water should prevent any paint stripping. An alternative to paint would be powder coating.
