289 Speedometer
289 Speedometer
OK, going to stick my neck out here and say that I think I've got the speedo as accurate as is reasonably possible.
Changes from CAI-supplied instrument:
1 - addition of part number and rpm figures (SN5321/06, 1020) below needle boss (my US sources describe these as correct numbers for a later, c. Oct-Dec '64 car).
2 - removal of paint and polishing of rivet holding zero stopwire in place
3 - replacement of CAI-fitted needle with the correct plastic type, salvaged from old instrument (MGB)
4 - repainted centre boss trim of needle with satin black
Notes: this speedo has 'MADE IN UK' at the base, hidden by the glass retaining ring. COB6029 has this rather than 'MADE IN ENGLAND' on both speedo and tacho, which are original, so I think this can be counted correct. It seems both were used, sometimes mixed but usually both the same. The part numbers etc. which I have added are in 1mm size waterslide transfers, cut as separate digits and applied individually under magnification. After drying these were given a coat of Revel modelling varnish mixed in the ratio of 2pts gloss to 1pt matte.
I think the 'MPH' should actually be a slightly thicker (bolder) font, but there's a limit, even for me. I think this is definitive, but am happy to be corrected with any further thoughts.
Colin Newbold
Re: 289 Speedometer
Post by Colin Newbold »
:roll:
Marsh
Re: 289 Speedometer
Post by Marsh »
Roger, I think you're right about the boldness of the font - sadly (and perhaps unsurprisingly) I was thinking exactly the same thing, but as you say, there is a limit, even though sometimes 'the limit' isn't immediately obvious to some of us.
The image of you applying the water transfers under magnification has me thinking of Donald Pleasance as 'the forger' in The Great Escape - I don't know why though!
It looks fantastic - detailing like this is important as the car becomes a historic document of what was correct in period. Without such attention to detail, things become lost over time.
Love it!
L
Colin Newbold
Re: 289 Speedometer
Maybe your two cars should be in some sort of automotive historical museum?
(Just me doing automotive hysterical musing!)
Re: 289 Speedometer
Marsh wrote:Roger, I think you're right about the boldness of the font - sadly (and perhaps unsurprisingly) I was thinking exactly the same thing, but as you say, there is a limit, even though sometimes 'the limit' isn't immediately obvious to some of us.
Love it!
L
Let me come with you... I can see perfectly...
(Hugh Dennis accent)
Colin Newbold
Re: 289 Speedometer
Love it!
L
Who?
Re: 289 Speedometer
Love it!
L
Who?
Fl.Lt. Colin Blythe
Colin Newbold
Re: 289 Speedometer
Roger King wrote:
Who?
Fl.Lt. Colin Blythe
Who?
Marsh
Re: 289 Speedometer
Post by Marsh »
OCD wrote:
Roger King wrote:
OCD wrote:
Who?
Fl.Lt. Colin Blythe
Who?
Roger, shall I say it, or should you?
Come on Colin, do keep up!
Colin Newbold
Re: 289 Speedometer
Gor Blimey! 'Ad to Google 'im in th'end. You're a mean pair.
Now I get it. Forger in the Great Escape, who lost his eyesight. I was reminded that someone from my old school starred in that film - John Leyton! Not to mention Stevie boy. But how they named Dickie Attenborough 'Big X' is beyond me. Aahh...the price of irony I guess. :roll:
Anyway, must go...more important things to do you know...
