MGB column bush
MGB column bush
If I grab hold of my steering column where it comes through the bulkhead (engine side) I can move it up and down more than I should be able to (not at home so cant put up a video) I’ll obviously have to take the column out but can anybody tell me what bush I will need for the lower part of the upper column?
Thank you
kenv
Re: MGB column bush
Post by kenv »
Just about to do that myself, assuming it's the early MGB column, it's on the MGOC site it's:- Bush - Lower - Felt 17H6565
Hope that helps?
Ken
Re: MGB column bush
Make sure it isn't the outer column moving in the hole in the footwell. I thought the bush in mine was worn but discovered there was a slight gap in the hole because the column comes through at an angle. A wee drop of epoxy adhesive filled the gap and all is now well.
Re: MGB column bush
I seem to remember having the same issue and re enforced the bulkhead with an Ali plate.
Jerryedmans
Re: MGB column bush
Post by Jerryedmans »
I bought a large heavy duty grommet that had internal diameter same size as outer sleeve of column. This mounts in the bulk head wall vertically, but because the column is fixed at an angle rather horizontally through grommet it wedges in the grommet slightly so no wobble or movement.
Re: MGB column bush
Thanks gents. The outer column is fixed pretty solidly in the bulkhead. It’s the inner column that has the play.
Re: MGB column bush
Video here....
https://youtu.be/FPd8TMhFgmE
Pics show column. Do you think it’s MGB or Gerry’s column?
Re: MGB column bush
That is an early B column.
That looks like the felt bushes have dried out. The quickest acceptable fix is to pack them out with thin card. Cornflakes packets are known to suit. The felt then needs to have oil smeared into them. When you reassemble the column the steering will initially be tight and will not self centre, but then loosens pretty quickly to an acceptable level.
The bushes are felt strips about 3/4" wide that are cut diagonally (where both ends mate) and seated in a recess at the bottom of the column. To get to them you have to remove the column, draw out the shaft and then you can get to the felt bushes. You might want to check and change the plastic bush at the top too!
Good luck!
Re: MGB column bush
Thanks Stu, will remove, assess and report back...
Re: MGB column bush
The reason for the play is probably a result of the top of the column shaft being pulled out more at the top to allow sufficient column shaft at the top to extend through the dash and allow the VW indicator switch and Boss to be fitted. It's the same with most cars mine included.
BTW. If you decide to paint your footwells White, use Innotec White construction primer and clear coat. Looks very similar to white gel coat. Masking up is a bit of a pain but the results will look splendid. Just need to key the surface with some 400 grit paper.
