catsx11
Post by catsx11 » Wed Jan 06, 2016 7:09 pm
Re: 289 slabside build
Post by StewbieC » Wed Jan 06, 2016 7:41 pm
Roger King wrote:
StewbieC wrote:Working in Maintenance for 20 years I've had my hands in far worse things than Denso tape. :twisted:
Listen mate, 35 years of dentistry (including the first 10 years in the pre-glove era) means my hands have been in much nastier stuff than yours!
You know how old people can smell of cabbage? Well, they keep quite a lot of it, semi-digested and often for weeks, under their dentures... and the feeling of satisfaction when you stick a scalpel in an abscess the size of a golf ball is quite something, although the pus has been known to hit the wall on the other side of the room.
I'm not going to argue with the "gaffer" at least us private patients have asparagus and samphire stuck in the recesses of our teeth! I was referring to the Jensen wuss by the way! But have to agree with Clints expression! Puss yuck!
Post by amulheirn » Wed Jan 06, 2016 8:36 pm
Glad I'd had my dinner before I read the above.
Post by amulheirn » Thu Jan 07, 2016 12:55 pm
Interlink just came, and we're all set for an evening of Denso tape and Molyslip OGL!
Moly-slip OGL and Denso tape for rear springs
Post by Roger King » Thu Jan 07, 2016 1:18 pm
Perfect, have fun.
Won't be very long before you realise why I wore latex gloves to do mine.
At least your springs will be hidden under the back of the car. My front one is well into the engine bay, and that blasted tape stays sticky and gooey for ever. Every time you rest your hand on it to reach something... yuk
Post by amulheirn » Thu Jan 07, 2016 10:57 pm
A bit disappointed to report that we didn't get very far tonight, owing to the replacement bolt supplied in the 'special packer' kit being too short. The manual says to remove the supplied bolt (3" long) and put the replacement bolt from the packer kit in. It doesn't say how long this should be, but what I've got is 3.5".
At this length and with both packers installed, there's not enough thread exposed to put the nyloc nut on. We compressed it a bit with the vice, but no luck as you can see:
Replacement bolt and packers for MGB rear springs - spacer removed
Replacement bolt and packers for MGB rear springs - spacer in place
Looking at Stu's photos in his built diary (page 2 of this PDF: http://www.the289register.com/stuart/Part%209.pdf) there's clearly plenty of thread sticking out of the top of the nut. Our bolt barely emerges from the black spacer to put the nut on.
A bit disappointed really, but I'll give Gerry a call in the morning.
Post by StewbieC » Fri Jan 08, 2016 10:20 am
Have you got the bolt fitted the wrong way round?
I don't think you use the cylindrical spacer. The machined head of the new bolt does that bit?
Just check and see and if you have any concerns I'll check for you over the weekend as I've got a spare set of springs with the original spacers fitted.
Post by amulheirn » Fri Jan 08, 2016 10:55 am
Thanks Stu -
Just heard from Gerry and the bolts should be 4" apparently. I think I've got the order right, looking at your photos. Unfortunately the pic in the build manual is pretty small and of limited use.
I've labelled the bits in this photo:
Cheers, A.
Hawk 'special packer kit' with MGB springs
catsx11
Post by catsx11 » Fri Jan 08, 2016 11:32 am
Post by amulheirn » Fri Jan 08, 2016 5:45 pm
Thanks Alan - that's a good photo and confirms what I thought I was doing is right! Phew...
