project insanity
Re: project insanity
Post by Roger King » Tue Oct 28, 2014 4:54 pm
agnoraan wrote:
Roger King wrote:Surely the next project should be one of those small Triumph sportscars?
What a Herald?? :wink: :lol: I really don't like Spitfires, horrible things to work on
cheers....Nige
Not sure anyone would describe the Herald as a 'sports' car... know what you mean about Spitfires. Huge floppy bonnet that never really fits, probably the worst rear suspension ever designed, and the list goes on.
I remember when Custom Car magazine used to refer to them as s*itfires, back in the early seventies... ah, happy days
Post by agnoraan » Tue Oct 28, 2014 4:59 pm
cheers....Nige
They also called them "hairdresser cars" :lol:
cheers..Nige
Post by nikbj68 » Tue Oct 28, 2014 5:35 pm
...It`s just the idea of a Spitfire & a Messerschmitt in the same garage that amuses me, one Focker of a project! :lol:
Post by agnoraan » Tue Oct 28, 2014 5:59 pm
nikbj68 wrote:...It`s just the idea of a Spitfire & a Messerschmitt in the same garage that amuses me, one Focker of a project! :lol:
At one point I had four Messerscmitts here,........... I had my own little squadron :lol: :lol:
cheers...Nige
Post by Roger King » Tue Oct 28, 2014 6:17 pm
cheers...Nige
Staffel, surely? You little red baron, you... and I mean little, those things are minuscule. But valuable.
Post by agnoraan » Tue Oct 28, 2014 6:30 pm
cheers...Nige
A "tiger" 4 wheel 'Schmitt is worth around £250K for a mint concours one. These that I'm doing are worth £35K ish...a lot of money for a very small car
Cheers...Nige
Post by agnoraan » Mon Nov 10, 2014 2:13 pm
Well, the weather was good today so I thought I'd make a start on the grille. Using the template that Alan sent me I was able to determine the shape of the 289 grille apperture. I formed a piece of mild steel to shape & fitted it using grips. Some holes were also drilled so that the piece could be screwed into place later
After double checking with the template, and being happy with that, I then made the swage that runs under the top flange & tack welded it to the top piece
The new panel was then removed & the lower valance of the car was cut off
cheers..Nige
Post by agnoraan » Mon Nov 10, 2014 2:23 pm
The new panel was then ground smooth & given a coat of etch primer for protection & screwed into place
A cardboard template was the made to replicate the new lower valance
This was then transferred to a sheet of steel & was the loosely fitted to the body with panel clamps. I also put a curvature in the steelwork to replicate the original, so the next thing on the agenda will be to weld it to the lower grille & then cut out the opening for the air duct. Once that's done, I'll be fitting it to the car & laying up the fibreglass. I find it easier to work in steel for stuff like this & then use it as the mould for the 'glass panels. I'll lay up the gelcoat inside the panels I've made & then give it two layers of 450 gramme fibreglass matt & resin. Once cured I can unscrew these new panels & hopefully it should leave a nice fibreglass panel bonded to the original car, fingers crossed & all that stuff.
The whole thing only took just over two hours work so I'm very pleased with that. :D
Cheers...Nige
ps why can't I post more than 3 photos in each reply??, it just comes up as an error all the time.
Post by Roger King » Mon Nov 10, 2014 2:42 pm
Nige, use photobucket or similar. It's free and you can embed as many photos as you like. I've given up trying to post pics direct to the website due to error messages and full quota stuff etc.
Post by agnoraan » Mon Nov 10, 2014 2:53 pm
Roger King wrote:Nige, use photobucket or similar. It's free and you can embed as many photos as you like. I've given up trying to post pics direct to the website due to error messages and full quota stuff etc.
Hi Roger, I do use photobucket on here, but it only lets me post three at a time for some obscure reason :(
cheers..Nige
