project insanity
Re: project insanity
Post by Migge » Thu Mar 19, 2015 4:40 pm
That's why I prefer a weldet tube tunnel. It's not totally safe but better as the GRP alone.
Post by Paul Blore » Thu Mar 19, 2015 4:43 pm
It really doesn't bear thinking about. As rare as these events are, it only needs to happen once to really spoil your day and in a Cobra, the flywheel is probably in line with your shins and a wayward flywheel or clutch would make a real mess. :shock: :cry:
I think that's very wishful thinking on your part Migge. A few small tube aren't going to present any kind of barrier for an exploding flywheel and will in all likelihood, only add to the flying shrapnel.
Post by Migge » Thu Mar 19, 2015 4:53 pm
Don't destroy my "btter than nothing" feeling :(
Post by Paul Blore » Thu Mar 19, 2015 4:58 pm
Migge wrote:Don't destroy my "btter than nothing" feeling :(
Rather that than your legs Migge. :cry:
However, you're probably safe, because the engine actually needs to be running for it to present a danger. :wink: :lol:
catsx11
Post by catsx11 » Thu Mar 19, 2015 5:39 pm
Post by Roger King » Thu Mar 19, 2015 5:49 pm
Let's keep a sense of proportion chaps - Ford production cars of the period, millions of them, used aluminium cast bellhousings. Under normal usage, including some pretty powerful cars, this is perfectly adequate. If you are going to drag race, with 1-2,000 horsepower unleashed in a fraction of a second, a bit of extra strengthening might be a good idea. OK, Mustangs had a thin sheet metal tunnel which might help a little bit, but I have never come across a Mustang, or any other sixties Ford, have a bellhousing shatter under normal and reasonable spirited fast-road use. If you're building a track car that might be a different matter - but original 289s and 427s had cast aluminium.
Post by Paul Blore » Thu Mar 19, 2015 8:42 pm
There are plenty of pictures on the net of relatively mundane cars that have had a flywheel let go Roger. Granted, they were being abused, but it does happen.
The thing to bear in mind with the '60's Fords is that the flywheel was well forward of your feet so even if the flywheel did let go, you'd still be okay.
As I said, it only needs to happen once to ruin your day.
Post by Migge » Fri Mar 20, 2015 8:58 am
Paul,
The engine needs to run?
Post by Paul Blore » Fri Mar 20, 2015 9:54 am
Migge wrote:Paul,
Yes, sorry Migge, we didn't make that absolutely clear. The engine needs to be running to present any risk whatsoever. On that basis, you're going to be completely safe, probably indefinitely. :wink: :lol:
Post by Roger King » Fri Mar 20, 2015 10:03 am
Be nice to Migge. He's never heard an engine running in a Cobra. Migge, what you'll find is a very loud noise coming from somewhere under the bonnet, with more coming out of the back (or sides) of the car. This is called a 'running engine'. Don't worry, it's supposed to do that - but it might be a way in the future yet.
Hang on, who am I to talk? Fourth year, and counting...
