SBF headers
Karl
Re: SBF headers
Post by Karl » Tue Jan 22, 2008 4:47 pm
Thanks Clive
Are you using 2" pipe to come down at that point? What part is leaking so badly on the engine?
Regards Karl
Re: SBF headers
Post by clive » Tue Jan 22, 2008 9:02 pm
Hi Karl,
I'm not too sure about the pipe diameter but I think it is 2" (It was supplied by Gerry along with the exhaust)
The oil leak is minimal. It is coming from the timing chain cover at the crankshaft oil seal. It is so slight I don't need to top the oil up at all, but it makes a mess of the underside of the engine. At least it will stop the rust!
Re: SBF headers
Post by Roger King » Tue Jan 22, 2008 11:01 pm
If you're going to fix your alternator on the Right side of the engine, why not just get a set of mounting brackets from a Mustang? You can get them from all the specialists - hundreds of thousands were made...
Karl
Re: SBF headers
Post by Karl » Fri Feb 22, 2008 12:23 pm
Received my headers from the US today, and what can I say: " They fit perfect"
Looks like there is nothing to modify, nearly impossible!
Karl
Header 002.jpg (73.87 KiB) Viewed 7869 times
Header 001.jpg (78.64 KiB) Viewed 7873 times
James Baxter
Re: SBF headers
Post by James Baxter » Sun Feb 24, 2008 9:49 pm
I had to modify our set of headers (Grrrr)- stock items from Gerry, and buy a short starter motor too.(Grrrr) Summit Racing along with the water pump as someone advised me on another thread.
Our alternator fits on the RHS - there are stacks of tapped holes on the head and water pump so making a simple backet is easy. The long bolt, on which the alternator pivots needs support immediately under the bolt head, ie outboard of the alternator; with a straight stay onto a water pump tapping. The slotted tensioning bar isn't enough to hold it (in my humble opinion). Fortunately the wiring loom still reached it on the RHS.
By the way, your new header clears lovely, but will the next length of pipe which bolts to it?
Also intersted in all AC's, Frazer Nash, Pre-war cars
Re: SBF headers
Post by Roger King » Sun Feb 24, 2008 11:29 pm
James Baxter wrote:I had to modify our set of headers (Grrrr)- stock items from Gerry, and buy a short starter motor too.(Grrrr) Summit Racing along with the water pump as someone advised me on another thread.
Shouldn't think so James - Gerry's headers go to a 90º radiused section, with a clamp fit, which none of the yank setups use. Karl will need to do a bit of fabricating here now, I think!
As I've said before, if you're fitting an alternator on the RHS of the engine this is the stock fitment for all small block Fords. You do not need to fabricate any brackets or bolts - there are hundreds of styles, Ford and aftermarket, pressed steel cheapo to super-expensive billet aliminium ('cept they call it aluminum) on the market. Why make something that is incredibly readily available? The stock setup is strong, and will not fatigue/break etc. Millions of Fords had it from the factory.
Here - $14 - that's £8 + postage!
http://mustangsunlimited.com/itemdy00.asp?T1=AB6573+01
Or you can spend proper money if you want to look flash:
http://bmc.name/store/products/Roush_Pe ... 8-227.html
Karl
Re: SBF headers
Post by Karl » Mon Feb 25, 2008 7:14 am
With the headers I got two angled reducers (2,5" to 2,25") which can be rotated. I will now weld a 2,25" 90 deg. bend onto them ( maybe some adjusting of the angle with the grinder is needed), but that should be all what is needed.
With the alternator position, see my reasons for changing the position in my other post. On my waterpump I have the threads for fastening only on the LHS also.
Karl
reducer 002.jpg (56.49 KiB) Viewed 6517 times
reducer 001.jpg (62.17 KiB) Viewed 6514 times
Re: SBF headers
Post by Roger King » Mon Feb 25, 2008 9:34 am
Karl wrote:On my waterpump I have the threads for fastening only on the LHS also.
Karl
Do you mean RHS? I've never seen a SBF water pump body extending to the left of the timing cover. As I said, all stock Ford SB alternator mounts - http://mustangsunlimited.com/itemdy00.asp?T1=AB6573+01 - go on the RHS.
James Baxter
Re: SBF headers
Post by James Baxter » Mon Feb 25, 2008 9:57 am
Derrrrrr!
Got my lefts and rights muddled! Very sorry.
I used part of an original bracket from the RHS mount, and fitted it to the left. My dead easy bracket was dead easy because it was simply a pair of spacers, owing to the fact that the right bank of cylinders is further back.
My headers (C'mon, exhaust manifolds) needed extra mod as we are 351W, but, the fore and aft clearance was wrong too, where the 351W should only be taller. I agree Gerry's are better for being a sliding fit, but they still came perilously close.
A flanged joint would never had fitted on ours. (Ours = My brother Richard pays and I spanner)
Rave on,
JB
Karl
Re: SBF headers
Post by Karl » Mon Feb 25, 2008 10:41 am
Roger, LHS when you look from behind, RHS, when you stand in front. Picture is in this thread.
Karl
