Visual Experiment
Visual Experiment
Post by Dave Woodward » Sun Oct 30, 2016 10:11 pm
With a little heavy gauge lining paper and a can a grey spray paint I've tried to mock up some fake arches on a nice set of Avons. Looks good but not sure whether to commit. I suspect this will solicit some interesting yet polarised views :?:
Dave
Re: Visual Experiment
Post by peterc » Mon Oct 31, 2016 8:08 am
Dave,
That looks very 1964. Many standard cars whose owners wanted to go racing did just that. Personally I think it needs to blend in a bit more with a small curve into the wing and perhaps a small curve at the outer edge. If you could build it up in fibreglass and give it a bit of substance it would work better. You could progress to the next step and make one and offer it up as you have the cardboard sample.
Best of luck.
P.s.
I notice you still have the separate rear indicators. I can recommend the LED rear lights by Spyida and then swop the separate indicator units for reflectors.
Petechia C
Post by Migge » Mon Oct 31, 2016 8:54 am
Go for it Dave, looks good.
Dale Bowman
Post by Dale Bowman » Mon Oct 31, 2016 12:57 pm
I think it looks great Dave
There are 3 types of people in this world
Those who can count and those who cant
DB427SC #006, 427 SO, Toploader
1965 Daytona Coupe ~ Sold
Post by StewbieC » Mon Oct 31, 2016 7:12 pm
I like the rear Sebring arches. Thumbs up fro me!
Post by Dave Woodward » Mon Oct 31, 2016 10:37 pm
peterc wrote:Personally I think it needs to blend in a bit more with a small curve into the wing and perhaps a small curve at the outer edge.
Go easy. It's only lining paper! :D
Post by peterc » Tue Nov 01, 2016 12:12 pm
Yes, Dave I realise it's only a paper cut out but assuming that you will convert if to fibreglass maybe you can give some substance and blend it in a little. If it was the same shape in Ali I think it would look a bit of an add on and not intended bearing in mind the remainder of the car and it's curves.
Post by nikbj68 » Tue Nov 01, 2016 12:21 pm
Like it, Dave.
Granted, it`s a less common shape to the Slabside/FiA/427 variants, but that`s what makes Cobras great... Vivé la Difference! 8)
Post by Dave Woodward » Tue Nov 01, 2016 2:59 pm
Peter,
In reality I would have the below more in mind which I suspect is closer to your thoughts.
Post by StewbieC » Tue Nov 01, 2016 7:12 pm
Colour change too? :P
