Brake test switch
Brake test switch
Post by simonjrwinter » Thu Dec 06, 2018 10:16 pm
Is a test switch required in the brake warning light circuit for IVA or is the handbrake switch considered sufficient?
Thanks
Re: Brake test switch
Post by clive » Fri Dec 07, 2018 9:01 am
Back in the day, the handbrake switch was the test switch for the brake light warning circuit. I don't think that the wiring has been altered.
Post by simonjrwinter » Fri Dec 07, 2018 9:51 am
Thanks Clive. I thought it might be a bit daft to have two methods of testing.....
Post by amulheirn » Tue Dec 11, 2018 1:52 pm
I didn't realise this, but there was an almost invisible test button on the top of my reservoirs - the IVA tester found it. Mine was a very small white plastic sticky-up thing, and the cap was also white plastic, so I had no idea it was there
So if you have a reservoir from Gerry that looks a little bit like this, see if yours has one of these too. :
https://www.carbuildersolutions.com/uk/ ... voir-130mm
Jerryedmans
Post by Jerryedmans » Fri Jan 04, 2019 2:46 pm
I asked same question. There were no buttons on the reservoirs provided in Gerry's brake kit, but the way they tested mine was by unscrewing the lid of the reservoir and lifting it out. The float sinks drops to the bottom and makes contact and the light comes on.
