BRA289 customized recreation
Part 3
If somebody is interested and for the Rover section. Inside everything is done: bored to 3.6 liters, omega forged pistons 10:1 comp ratio, balanced and tuffrided bottom end, holbay mid range solid lifter profile camshaft, small block chevy solid lifters, steel push rods, adjustable steel rockers, twin valve springs, std heads, main bearing stud conversion, shot peened H section rods, polished and drained valley.
I bought the engine with two ankled manifold (good when the engine is not horizontal but the carbs are), all 4 Dellortos faced in one direction, easy línkage function! I wanted the linkage in the center so carbs face to face and the fuel lines outside.
If you want to use Ford valve covers you have to use the adapter plates. If you want to use Weber IDF or Dellorto DRLA carbs you have a problem: No space.
Old manifolds:
Old manifolds:
New TVR manifolds without bores for the studs
Adapter plates touches the manifold
Better to see
Grind down the manifold (and grind down TVR ) and the plate and it fits
Better to have 2 mm space
Approx. 5 mm from the manifold and the plate
One manifold was already weldet the other one not (where you have to place two studs
I grindet all material down that was no need for to place the carbs.
