With regard to throttle linkage
Re: With regard to throttle linkage
It is as engine builder fitted and the same as all other Edelbrocks I’ve had.
simonjrwinter wrote: Wed Mar 06, 2024 10:46 am Is the carb on “back to front”?
If it was on "back to front", surely the throttle link would be on the opposite side?
Interesting. My Edlebrock has the throttle linkage on the near side.
Mine too…..
https://www.the289register.com/phpBB3/d ... php?id=428 Looking back through the forum i found this picture of Roger's car. Admittedly it's a Ford engine but the fulcrum appears to be further back.
Another thought is what manifold are you using? It appears to be rather high hence your need to have the air filter pan stepped down. I had to change my inlet manifold to a low profile Edelbrock Performer to give me the clearance. If you could do that then there would be more clearance under the air filter.
Now finished and seems to work well. Made a new bracket and did a LOT of playing with the linkage to get full movement of the accelerator pedal/carb
StuBaker
Post by StuBaker »
Nice work.
Nice work. How is the assembly connected to the throttle pedal?
On top of the foot box (pic taken before everything was connected up!)
