Still a bit clackety as solid lifter lash is not set yet - they have to be done hot, and I did them immediately after this run up (basically whip off R side cover as quickly as possible then set no.1 I and E hot. Leave overnight to cool and those two should show what the cold setting needs to be, so set all the others to that.
Need to find a way to get the idle down a bit without retarding the ignition, as I'm only getting 22-24° all-in, but it looks and sounds promising now! Need to think about an MOT.
Strange how the phone attenuates the sound level...
It runs!
Re: It runs!
Looks lovely Roger, congratulations.
Re: It runs!
I think... that may be... a compliment? Running like a sewing machine? Or a hint I should take up knitting?catsx11 wrote:Well done! Have to admire folk like you!
although tongue-in-cheek,the sound reminded me of something... I couldn't resist posting this up
https://youtu.be/-0AoJ3UhBao
Re: It runs!
Congratulations!
Re: It runs!
MOT test, trying to fine-tune (bit of a distributor issue appeared - damn these date-code original parts), then hood and tonneau, then drive
Re: It runs!
Once it's sorted - I'd like to inspect/rebuild the double VANOS system on my S54 M3 engine. Bit different technology, though.Migge wrote:So whats next Roger?
Re: It runs!
Well done Roger, looks and sounds grand!
Re: It runs!
Roger King wrote:Once it's sorted - I'd like to inspect/rebuild the double VANOS system on my S54 M3 engine. Bit different technology, though.Migge wrote:So whats next Roger?
Gulp!!
