‘Clear out’ parts - collection at Stoneleigh if required
Like
You liked this
Hi, I’m having a clear out, and can take parts to Stoneleigh for collection, or despatch via Hermes at cost.
Lumenition Optronic PMA50 ignition module only, unused, but no box and small white block connector is absent, NOS (New Old Stock): £50.
Universal choke cable, 1.9m long, twist to lock, unused, NOS £4.
Universal bootlid support stay, min.length 29cm, max 49cm, used but good, 2 available, £5 each.
Universal bonnet or bootlid support stay, with ‘lift to release’ safely catch, min.length 32cm, max 55cm, scruffy but safe with great patina, £3.
Rover SD1 V8 9.5” 241mm clutch friction plate - genuine Borg & Beck 52509, New old stock: £45.
Rover V8 clutch release bearing and carrier, used but smooth rolling: £5.
Rover SD1 V8 sump with pick up pipe and baffle. Battered, dented and scraped, but doesn’t leak paraffin when tested: £10
Rover SD1 V8 front timing cover ERC0036, bare, with hole for dizzy: £70.
Range Rover V8 front timing cover HRC1321, bare with hole for dizzy: £70.
Rover SD1 V8 alternator mounting bracket ERC0303: £10.
Rover SD1 V8 41673A 35DE8 distributor with Opus electronics, bit scruffy but has the important skew gear with oil pump drive and rotor arm, so £30.
Range Rover V8 42649A 35DLM8 distributor with 9EM ignition module, scruffy but has the important skew gear with oil pump drive and rotor arm, so £30.
Rover V8 remote extension RKC3406 with gear-lever and knob for 5 speed manual gearbox - housing a bit worn on shaft supports, so ideal for rebushing or shortening: £25
Rover SD1 V8 water pump pulley for v-drive belt, scruffy: £3.
Rover V8 dipstick and tube, 53cm long: £3.
Please let me know if you’d like photos of anything.
Regards, Martin.
Regards, Martin.
Like
You liked this
Re: ‘Clear out’ parts - collection at Stoneleigh if required
Hi, an update:-
Universal bootlid support stay, min.length 29cm, max 49cm, used but good, 2 available, £5 each. SOLD
Universal bonnet or bootlid support stay, with ‘lift to release’ safely catch, min.length 32cm, max 55cm, scruffy but safe with great patina, £3. SOLD
Rover SD1 V8 sump with pick up pipe and baffle. Battered, dented and scraped, but doesn’t leak paraffin when tested: £10 SOLD
Rover V8 remote extension RKC3406 with gear-lever and knob for 5 speed manual gearbox - housing a bit worn on shaft supports, so ideal for rebushing or shortening: £25 SOLD
Regards, Martin
Regards, Martin
PM SENT re 35DLM8
Thanks
Thanks
- nikbj68
Like
You liked this
Thanks for all of my goodies!
Like
You liked this
You’re welcome Nik - I’m pleased they’ll be put to good use!
Regards, Martin.
Regards, Martin.
- nikbj68
Like
You liked this
...Probably sit in the corner of the garage for a year or 2...!
Like
You liked this
hi ,
is the dipstick and tube still available?
thx stuart
thx stuart
Like
You liked this
Like
You liked this
great. i think i have sent you a pm. let me know if you dont get it
thx Stuart
thx Stuart
