Clear out parts - mostly Rover V8 - now SOLD
Martin D-S
Post by Martin D-S » Sat May 11, 2019 12:21 am
Hi, I’ve been having a clear out, and can despatch via Hermes at cost.
Lumenition Optronic PMA50 ignition module only, unused, but no box, NOS (New Old Stock): £50.
Universal choke cable, 1.9m long, twist to lock, unused, NOS £4.
Rover SD1 V8 9.5” 241mm clutch friction plate - genuine Borg & Beck 52509, NOS: £40.
Rover V8 clutch release bearing and carrier, used but smooth rolling: £5.
Rover SD1 V8 front timing cover ERC0036, Rare - gives low level water pump. Bare, with hole for distributor: £50.
Range Rover V8 front timing cover HRC1321, More common - gives higher level water pump. Bare with hole for distributor: £50.
Rover SD1 V8 alternator mounting bracket ERC0303. Normally underslung, easily modified to overhead: £10.
Rover SD1 V8 41673A 35DE8 distributor with Opus electronics, bit scruffy but has the important skew gear with oil pump drive and rotor arm. Ideal for converting to Lumenition. £30
Rover SD1 V8 water pump pulley for v-drive belt. Black painted: £10
Rover V8 dipstick and tube, 53cm long: £3.
Please let me know if you’d like photos of anything.
Regards, Martin.
Martin D-S
Re: Clear out parts - mostly Rover V8
Post by Martin D-S » Wed May 22, 2019 10:14 pm
A quick update:-
Rover SD1 V8 water pump pulley for v-drive belt. Black painted: £10.
Regards, Martin.
stu60
Post by stu60 » Fri May 24, 2019 9:31 am
Just wanted to say big thank you to Martin for dipstick.
Excellent communication, excellent description and packing!
regards Stuart
FIAJack
Post by FIAJack » Thu May 30, 2019 3:55 pm
Martin,
PM sent re. Lumenition
Jack
Martin D-S
Post by Martin D-S » Sun Jun 09, 2019 12:55 pm
Hi,
Another quick update:-
Rover SD1 V8 9.5” 241mm clutch friction plate - genuine Borg & Beck 52509, New Old Stock: £40. £25
Regards, Martin
Martin D-S
Post by Martin D-S » Mon Jun 24, 2019 3:32 pm
Hi,
And another update:-
I have only the distributor and water pump pulley remaining - these are now on eBay , but contact me if interested.
Rover SD1 V8 41673A 35DE8 distributor with Opus electronics, bit scruffy but has the important skew gear with oil pump drive and rotor arm. Ideal for converting to Lumenition. £30 £25
Regards, Martin
Martin D-S
Now SOLD. Clear out parts - mostly Rover V8
Post by Martin D-S » Sat Jul 27, 2019 10:06 pm
All items now SOLD.
Thanks for your interest.
Regards, Martin.
