Has anybody had any success with shortening their own handbrake cables? I need to shorten two Jag cables and my only options seem to be to send them halfway across the country to somebody like Speedy Cables. Unable to find anybody local that can do this.
The next challenge would then be how to post the buggers. I don't want to tie then in a knot as the outer casing is quite solid.
If you have done this yourself, what did you use in replace of the standard pressed 'stop' at the driver end of the cable?
Shortening Handbrake Cables
- Dave Woodward
Re: Shortening Handbrake Cables
Not done it myself. If you need someone else to do it, I recommend these people heartily: http://www.speedograph-richfield.com
In the good old days I used to solder on my push bike brake ferrules. Never any problems there. I thought I'd try with my Hawk handbrake but I think solder/flux/metal combination was wrong. It didn't work.
In the end I drilled out a steel rod and crimped it in the vice, rotated a couple of times. I then added a further welly with a chisel just to be sure. Just drill as tight as possible and maybe chamfer or countersink the 'live side' of the ferrule so that any burring won't chafe the cable.
It hasn't budged... yet.
I did something similar to Stu.
It's holding up so far.
A heavy duty cable crimper would do the same.
- Dave Woodward
What kind of thing do you have in mind Stu?
- nikbj68
50kn do you?!
- Dave Woodward
Do you have one to fit a 3mm handbrake cable
- nikbj68
Do you have access to new fittings?
- Dave Woodward
I've been unable to find anybody that sells them. The only option seems to be to send the cables away.
I'm currently 'manufacturing' my own stops from 8mm mild steel round bar, drilled out. The challenge I have is securing them well enough for me to 'hang off' the handbrake during an MOT.
If you know anybody who sells the compression fixtures I'd happily follow a link.
Thanks again.
Thanks again.
