New member
Re: New member
Have a look here http://www.the289register.com/stuart/Part%201.pdf
Re: New member
Do you think the Hilka pro craft spring compressor at screw fix will be squat enough to work ?
Re: New member
I've got a set of Draper expert very similar in design to those the Hilka ones and I couldn't get them in. The photo at screwfix shows a Spring that is much more open.
Re: New member
Hello people,
I'm gathering bits and pieces for my ace and am going to fit SU HS 4 carbs. Would any set work, a pair from an mgb for example. I presume they will need new needles
I'd be glad for any advice, thanks.
Ian.
Ian.
Re: New member
I'm fitting a triumph 2.5
Re: New member
I think you might be in luck that the MG and Triumph 2.5l 6 both use HS6's.
If in doubt speak to an SU specialist and see what they advise. SU have a phone number an I think they still manufacture the carbs out of Salisbury.
Re: New member
Thanks for that.
- nikbj68
Re: New member
Upgraded from HS4’s to HS6’s on Dad’s 2.5, but that is in an AC Greyhound.
Re: New member
Date not set in stone but 17months until my kit arrives....
Bought an old mgb and not sure what to do with it. I will use the v5 which will leave me with an unregistered car. As I am using a triumph engine/gearbox, and I have already prepped the front suspension from another car there’s not much I need mechanically from the donor. Would it be better so try and sell the complete car or take the few remaining parts off it and scrap the rest. I don’t have a workshop or much space, I will rent a garage when the kit arrives.
Re: New member
Are wire wheels/hubs much heavier than bolt on alloys. Wire wheels look nice but it’s the unstrung weight I’m thinking of.
Any thoughts would be welcome
Thanks.
Thanks.
