hawk ace iva
donfrost
hawk ace iva
Post by donfrost »
Hi have got iva booked in at Gillingham on the 4th of october very scary!! few bits still to sort on my hawk ace.looking to buy or borrow set of octagonal wheel nuts and a steering wheel pref 15 inch to fit collapsible boss from europa and any last minuet hints on things i must have forgotten or not even known about, or even wish me luck!!!!!
have still got set of painted wires off of an mgb so are 14inch i used them for my build, tyres not go through mot , wires although old not to bad a condition , would have to be picked up from hastings area
also got front and rear mgb Armstrong dampers in good cond
thanks Don
jackfrostuk
Re: hawk ace iva
Post by jackfrostuk »
oops got date wrong its on 4 th of november
Don
Re: hawk ace iva
Good luck!
Make sure you don't have stickers on your dash, but permanent labels for switches - Gillingham failed me on this (and many other things) first time around.
donfrost
Re: hawk ace iva
Post by donfrost »
thanks Kevin
would dyno printed labels be accepted ?
Don
Re: hawk ace iva
Doubt it very much, probable best to order something like this....
TR6 (V8) Hawk 289 FIA (V8) GTD GT40 (V8) Doing my bit for global warming.
Re: hawk ace iva
As what Simon said.
This was how I presented my car - I think they look OK actually, although the under dash binnacle was a bit rough.
You'll also need to make sure the fuel filler hose has suitable marking like in this pic.
Re: hawk ace iva
I found Gillingham to be firm but fair.
If like me you hung a pair of fog and reversing lights under the rear valance, make sure you don’t just rely on the mechanical friction of the bolts holding them in position. The tester put my car up on the ramp, walked underneath and as he did so, tapped both units with his hand. They both folded up under the boot floor “that’s your first fail” he said.
For the re-test an aluminium bracket behind each light held them in place to his satisfaction.
Switch labels need to be permanent and resistant to weather in an open top car.
Having said that, the transfers from CBS passed on my car although didn’t on others!
